I've posted elsewhere but no response.
It's a 2012 997.2 S with PDK.
I have a rumble on the highway in 7th traveling at 70-80 mph at a frequency of about 4 seconds.
It has been present since I obtained the car a year ago. Tires are newer and show no obvious abnormal wear. The vibration seems to permeate the entire car, not just through the steering wheel. It isn't horrible, but I want to catch something early to avoid an expensive failure down the road.
Am I losing a CV joint?
CV joints are usually heard when shifting from reverse to drive - as a clunk. Which is free play in the CV joint.
More likely tires or even a wheel bearing - though wheel bearing are usually felt and hear on the side they occur on.
How many miles?  When was the last PDK service (and did they use Porsche fluids)?
