I have a 2000 2.7 manual Boxster with 170k miles. My rear suspension makes a awful squeak. I’ve located the area. It’s right where the bottom of coil sits in the pocket on the shock assembly. If I lube it with oil it gets much more quite but only for a short time (like a day or two and returns). This problem started when I power washed the underside of the car. I looked at some assembly diagrams and it doesn’t look like a bushing or anything goes between the coil and the seat. Has anyone come across this issue?  The squeak is really loud and almost embarrassing. The car rides well but just sounds terrible.
