So I sent my ECU (DME) to get it checked and repaired if need be. Turns out the programming was corrupted (so they say) and they have to reprogram it to my specific car.
Does this sound right??? Thanks V
Yes, that can be correct as one DME can be used in multiple versions of the car, which may have different equipment and control networks that the DME needs to be aware of to function correctly.
Ok...so that may be my issue then? My issue on a different thread :
Edited by vza
Possibly.
First of all, if the DME is corrupted, just about anything is possibly connected to that fact, the only way to find out is to correct the DME and see what happens.............
