Quote
Transmission stuck in Park position unable to communicate with the TCM module all electrical connections are OK I replaced the TCM module but it is still stuck!
Have you looked for a mechanical fault with the shifter?
Sometimes thing fall down into the shift mechanism and jam the lever.
  • 9 months later...
On 4/24/2024 at 7:13 PM, Eric Pascal Sialeu said:
Transmission bloquée en position Park impossible de communiquer avec le module TCM toutes les connexions électriques sont OK J'ai remplacé le module TCM mais il est toujours bloqué !
I'm having the same exact issue . Did you fix it? Please say yes
