I bought a beautiful car that had a small front end collision.  Air bag and drivers belt both deployed.  I’ve used seatbeltmasters service to clear the crash data and reload the belt. All previous errors are gone but I cannot get rid of the 8057 code. A previous post describes the code as “AWS control unit read out fault memory”  but had no resolution.  I’d appreciate any insights.  Thanks 🙏
8057: Apparently, whenever a belt is triggered, the AWS (Auto or Advanced Weight Sensor, depending on where you read it - the passenger seat weight sensor ) needs to be calibrated using the PIWIS. This is done automatically when the tool is plugged in and takes a minute.
