I installed the short shift kit into my boxster ('03, 2.7) but I did not mark the ends of the cables. *after* completing the job, I noticed that the car ground gears going into second from first...a sign that the cables were not installed quite right, and need adjustment.
Does anyone know the procedures to properly adjust the transmission cables, or should I just take the car to my local shop (TPC) and ask them to do the adjustments? I can't believe the task is so difficult, that it's beyond a determined man w/ tool's abilities.
My email's the best way to get in contact with me:
the_meatball@yahoo.com
There is a tool to adjust the cables but it will not work with a B&M.
Just take your console off and try the trial and error method. If you are lucky you may be able to see wear marks from where the cables were originally.
