Hi All, hope I'm not digging up a horse flogged to death...
I want to service my 1997 986 "early" type oil cooler (no bleed nipple on top etc), anyone know the oring sizes?
Many thanks
The 1997 car used a different set up than the later ones, using an adapter plate between the cooler and the engine case, and a different cooler itself, so your best bet is to check with a dealer part department for the correct o-rings as your setup is unique.
