2002 Boxster S I’ve been building for the track. Previous owner swapped the ECU and the immobilizer from another car with a matching key.  Engine starts no problem. So the new ECU and alarm is working just fine. However, I have codes for ABS and PSM.  Fuse E9 is good. Does anyone know where the relay is that the Porsche repair manual mentions in troubleshooting the error codes?
ABS/PSM 5.7 Error Codes:
P4276 Valve supply voltage
Instrument Cluster K21 Error Code:
9111 PSM/ABS control unit
I’ve been doing a lot of research on the web about new ABS control modules. And them needing to be programmed to the ECU to match the VIN. Is this correct? And if so, can that be done within the Durametric?
Edited by geoffbaltz
So, these error codes would represent the need to program the ABS control module?  And I am correct that is what is going on here?
