Hi guys, I'm planning to continue testing my driver's sided heated seat after ruling out a switch malfunction as a potential cause of the heated seat failing to activate.
There are a bunch of posts on this, and the relay is indicated as a potential failure point. I'd like to test it, and was curious if this relay controlled anything else on the seat, such as the power seat back adjuster? I ask because in many part descriptions (Porsche part# 996-618-521-00) I've read for the relay sound like it also switches power to the seat motors. Is this the case, or am I misinterpreting?
Thank you
