'01 986 ~110K miles, all original  O2 sensors. Check engine light periodically comes on, and then after driving a while turns off. Codes are P0139 and P1117. Is this indicative of anything other than an aging / failing O2 sensor?  This used to happen every couple of years, but now appears every few months. Car runs fine except for the light on the dash
P0139 is the code for the O2 sensor after the main cat on bank #1 aging out, P1117 is for the heater element on the same sensor.
  • Thanks 1
