I recently replaced the plastic guides to the cam chains on my 2000 2.7 Boxster. The car will not start. During the reassembly I accidentally pinched one of the spark plug wires and the insulation got torn but I can see the wires are intact. So wondering if upon start up if the spark shorted across exposed wires and took something out? Or what have I missed during reassembly?  The car turns over and I smell gas coming from the exhaust. It just doesn’t fire up. Any ideas what I can do or check?
Scott
Yes.  At TDC the exhaust cams were strait up and down and the intake cams were pointing inward both times depending what rotation i had the crank at.  Is that what you are referring to?
Test light or multimeter would work but start by checking for blown fuses.  If memory serves, fuse B8 should be one that controls the DME
Ok it looks like I have spark going to the plugs. I uninstalled one of the coils and rested the plug against the block while I had someone turn the ignition on. I still have a fuel smell coming from the exhaust so I think that’s not the problem either. I must have got the timing wrong with the engine. Let me make sure I have this right. Turning the crank to TDC should have bank 1 intake cam pointing towards the engine and the exhaust cam straight up and down. Rotating the crank 360 degrees should have bank 2 intake cam pointing away from the engine with the exhaust cam pointing straight up and down. Is that correct?  Or am I missing something?
Scott
