Hello all,
2003 996 with 6 speed manual transmission. The rod end rubber bushing on the shifter cable that attaches to the transmission end needs replacing. I had to cut out the rubber bushing as it was un-serviable.
From my research I'm mainly finding information that says I will need to replace the full shifter cable assembly from front to back.
I have found one company " Function First Performance " that appears to have what they call  "solid shifter cable ends" replacement for the 6 speed manual transmission. Any experience with this company and there products or other companies that make rod end replacements
Thank you in advance for
Edited by Loren
Made images viewable here
I had similar issue. I thought I could replace the end connectors and tried as hard as I could I was not able to unscrew the connector piece without the metal cable rotating. Looks like it was screwed in but I guess not. Even tried heat. Everyone recommends Function.
 hello Carlo, I found a company( "Function First Performance"  that sells an aftermarket upgrade/replacement bushing for the rod end that includes a tool for extracting the old bushing. AScreenshot_20240205-094322.thumb.png.23182a2c2eea7a126faeec61a9d84cae.pngs long as you use the bushing removal to correctly it is a awesome upgrade to the to the factory shifter rod ends. easy to install and IMO better then factory, thanks for your response
