Hello all,
2003 996 with 6 speed manual transmission. The rod end rubber bushing on the shifter cable that attaches to the transmission end needs replacing. I had to cut out the rubber bushing as it was un-serviable.
From my research I'm mainly finding information that says I will need to replace the full shifter cable assembly from front to back.
I have found one company " Function First Performance " that appears to have what they call  "solid shifter cable ends" replacement for the 6 speed manual transmission. Any experience with this company and there products or other companies that make rod end replacements
Thank you in advance for 20231214_210453.heic
