I'm in the process of replacing the plastic guide rails on my 2000 2.7 Boxster.  I managed to replace the guides and put the cams back in.  However now that I'm about to install the double chain sprocket back on the cam the 4 bolts don't seem to line up anywhere near the slotted holes in the sprocket.  I did remove the chain tensioner prior to removing the sprocket and it is still uninstalled.  I have a pin in the engine making sure its TDC.  Is there a way to align this?  I'm on the right-hand bank (I believe bank 1). Any help would be appreciated.
Scott
