Why the 996.2 with the Mersedes-Benz automatic transmission A96/50 (Mersedes 722.70) is having 2 reverse gears? In the instrument cluster there is only 1 light for Reverse gear. What are these 2 reverse gears are for?
For the 996.1 with a ZF gearbox there is only 1 reverse gear, same as in the manual transmission for either 996.1 and 996.2.
Edited by alex222
As you can see in your screenshot, the two reverse gears have different ratios.  This is particularly useful, for example, when on snow or ice.
