Yesterday I spent the time to put in a new shifter and e brake handle. I did it myself with the directions I got here. The directions were great, but it ended up taking two and a half hours instead of one and a half. I got the whole thing apart and together in 90 minutes or so but the the brake was rubbing on the plastic. So I tried to figue out a way to fix it without taking the whole thing apart again :oops: . I couldn't so I ended up taking it apart again and filing the plastic. So it took me longer, but it looks great in the end.
Thanks for the help.
I did the same thing on my car. It took me a while to figure why the console was rubbing the brake handle.
At the front mounting point of the console there is a steel bracket attached to the hump of the car. The console can be mounted wrong on this bracket and yet all the screws will go in, but the console will be shifted back out of position.
I can't exactly remember how it fits, but you will see if you look at the area.
Stan
