02 996.2 C2. Using OBD II smog test passes everything, but Cat monitor shows not responding. I believe the drive cycle for this is: Maintain speed between 55-60mph for 15 mins, no braking. Is this correct? Are there additional steps or requirements?
Welcome to RennTech :welcomeani:
If you are referring to the I/M Readiness test showing the cats are not ready, you may have a bigger issue.  The cats show ready when they meet certain electrical signal parameters coming from the O2 sensors:
If the cats do not meet this threshold, and the O2 sensors check out OK, one or both of the cats could be on the way out.
Here is the drive cycle that I found on the Rennlist forum.  I did exactly as this guy instructed, then drove to the EPA test station without shutting the engine off and passed with one failed item.
From Rennlist:  I passed my smog test in AZ 1 hour after resetting everything, roughly 25 miles after it. What I did was FOLLOW the drive cycle procedure to the T. This is what I did. I cruised at low speeds on 19th ave in Phoenix to get the timing. And timed myself with a stopwatch.
DO NOT EXCEED 60 MPH AT ALL COSTS!!!
1.    Start engine, let idle for approx. 2 min, 10 secs.
2.    Accelerate to 20-30 MPH, Maintain steady speed for approx 3 min, 15 secs.
3.     Accelerate to 40-60 MPH, Maintain steady speed for approx 15 mins.
4.    Decelerate and come to a stop. Then:
Idle in Neutral for 5 mins. (manual trans.)
5.    Idle in Drive for 5 mins. (Tiptronic trans.)
During the drive cycle, do not exceed 3,000 rpm or 60 mph.
Don't shut off the car before smog test. That is what I did, and I had a constant SAI pump error triggering CEL. Car passed the test.
