Any thoughts on my  2003 996 car key remote feature not working? I replaced the battery which made no difference.
Thank you for any considerations you may offer.
Bill
Bill
:welcomeani:
10 year old car - is the button worn so much it does not "click" anymore?
If so, then the contact of the button to the circuit board is worn out.
The simplest fix in to by a new key remote and transfer your physical key AND your transponder pill to the new remote.
Porsche sells a nice design key for that purpose and it requires no programming if you transfer the physical key and transponder.
"Porsche sells a nice design key for that purpose and it requires no programming if you transfer the physical key and transponder."
Do you have a part number I can look for?
