My key turned all the way to the right without hitting the detent position start the car.
I found out it was most likely the steering lock failed.
Ignition Switch
99634701707 with the steering lock
So I ordered that part from Sunset. In the mean time when I was ready to have it towed to my mechanic I thought I'd try the key again. Immediately notice it felt different and sure enough it was like the way it was suppose to be.
I decided to wait and see what happens and haven't replaced the part. Drove it a few times and everything seems fine.
I wish there was a way to lubricate the part but afraid to spray WD-40 or a dry lubricant because the tumbler is suppose to be coded and was afraid it might screw that up.
I couldn't find a link on here for a problem like it. Any advice would be welcomed.
2001 Boxster 5 speed 70k miles or so.
Edited by da888
