Can anyone explain how to pull my steering column?  I need to pull the steering lock (ELV?) to send to the cpu doctor to test my modules.  I pulled the bolt closest to the steering wheel and the little arm brace.  I cant figure out how to et the forward end out.  Any advice?
TIA,
John
You should be able to test the ELV with a PIWIS tester. Way easier than removing the steering column.
I think that only one screw holds the ELV in place - it's just a quest of being able to get to it.
