2002 996 Carrera "chirp" about 2 seconds after starting. Maybe door lock actuation may be something else. When it happens ABS light goes on. What is causing this? Seems related to "low voltage" OBD code but battery is only 1 year old.
The low voltage code was obtained by  the dealer. That code also plays havoc with my sunroof controls. Sunroof works but not as the owners manual says it should. After clearing the low voltage code, it was reset and worked until the low voltage code popped up again.
