Well, I have followed an excellent guide to DIY fitment of the cruise control stalk and associated wiring. All I need to do now is code the **** thing in. This is where I am struggling. I have purchased the Durametric Pro kit, but have absolutely no idea where I am going after that. I can view and amend codes for all installed modules, but have no idea which modules or codes I need to amend.
Research indicates that it is only the engine code that needs changing. Does anyone know if this is correct, or if I also need to change Gateway and / or instrument cluster modules? Bonus points if you know which codes I need to input. For example, under the engine module I am showing code 00133. I know that the 13 signifies steel spring suspension, and the three suffix is for auto transmission, so I suspect it is the leading zeroes that would need changing for cruise control, but what on Earth should I input?
TIA
