My '03 996 coupe with a manual transmission recently threw the P 0501 code which I am told relates to the Variable Speed Sensor. Has anyone remedied this scenario? Thanks in advance.
P0501 indicates the DME is seeing an out of range vehicle speed signal, this is usually either a wiring issue going to the wheel speed sensor, or and ABS control module issue.  More diagnostics are going to be necessary to determine which one is the problem.
