My 2006 987 needs a headlight bulb replacement. I’m looking at the owners manual for guidance; but need a little help.
I opened the carpeting to view the plugged opening. There’s a lower black plug and an upper blue plug. Is the black plug ghe one I use ?
and are there any tricks to using the unlocking lever
2 hours ago, jim_hoyland said:
After looking at a UTube video, it looks like the Round plug to the left is where the access is.
You are correct.
This went smoothly. I was surprised at the dirt that got into the area where the headlight assembly sits.
I put silicon grease on the rails that the headlight use as guide. Went in very easy
