Hi, hope that anybody can help me out..
Since a cple of weeks i got the System Warning "Cooling System Fault" (Yellow).
I check out for aleak and found that problem on the hose connection located at the thermostat. I fix that but the warning still comes around some times.
I dont loose Cooilng Fluid, nor the Cooling System and Oiltemperature rises above the allowable value.
I connect my Durametric and found 2 things:
1st: In engine module the Fault code P3300 Implausible Signal is active
2nd: I check out the graphs of different measurements: Cooling Fluid Temperatur outlet (Volt and C°) and Motor oil temperature (Volt and C°)
         I saw that that the Sensor for Coling Fluid Temperature outlet show up the Temperature steady but the Voltage rises between 0 and 9 Volt (like a sawtooth voltage, see       atached pic) - That could be the implausible Signal?
Now i am wondering if that could be the Temperature Sensor right behind the Radiator (located behind the left Front Wheel). Part Number is 94860642001.
Here are my questions:
- Do anybody now the meaning of Code P3300?
- Did anybody heard about problems with that specific sensor (because in the porsche part list i saw that an old part should not be use anymore)?
Thank you so much in advance for helping me out
