I have been using a 12 volt portable air compressor to inflate my tires. I would like to get dry air in the tires but I don’t want to spend a lot of money. I have search with google and found noting, any ideas?
If you do not track your car then do not worry about it. The normal pressure rise of 2-3# that occurs under normal street driving is not going to influenced that much by the water content in the air.
If you track then you are going to have to get a nitrogen bottle.
If you have a large tank compressor you should have a water trap on it anyway.
