What are you guys running for tires and sizes with these rims???
There's just not a lot of options for tire manufactures with the sizes...
So, I just ordered a set of S03's that are 235/40 and 285/30 and I'm starting to have second thoughts that maybe I should go with Yoko's that are 235/40 and 285/35...
I am worried that the set I ordered are going to be obviously different with the extra 1" diameter in the front versus the rears. I can always eat the shipping and order the cheaper Yoko's...
I have a tip, and it's a daily driver, so I am thinking going with a bigger tire on the back won't be an issue for me because performance is not #1. Comfort and noise are #1. Then wet traction, then tread life, and finally overall dry performance.
And 285/30's are about the same amount smaller than 285/35 are bigger than the original 265/35....
The extra side wall in the rear will also give added rim protection...
What's your advice?
Edited by PorschePRH
Loren, what size front rims do you have?
How do you feel about the 235/40's being about an inch larger than the 285/30's? Do you think it would be noticeable on your car?
