Does anyone make a replacement piece for the bolt/pin on the right hand side (the center piece). I realize this would require a drill out -- but it would be better than the zip tie setup that I have cobbled together.
I'm describing the center section that the assembly rotates around where the two red arrows are the outside pieces, and I'm looking for an inside piece replacement,.
