Hi Folks,
Recently had an unusual sound while turning the steering wheel.
Symptoms: Squeaking sound front left side of wheel when turning steering wheel to right.
1999 C2 996
How many miles on the car?
Could be left front wheel bearing or a worn ball joint or a worn tie rod.
You will likely need to put it on a lift and do at least a visual inspection.
Thanks Loren,
The car has around 118,000 miles.
Recently changed all struts with some tie rods. Will lift the vehicle and check left side suspension area
Regards,
Jose
Hey Jose, did you figure it out? I've experienced something similar, after a break job, where the metal shield was bent a little and it was ever so slightly rubbing on the rotors.
