I tried to create a DIY Tutorial but for some reason Rennlist deleted it...sigh.
These are the instructions along with necessary technical briefs to install the Tequipment illuminated door sills on your Porsche 981/991 vehicles.  The complete kit can be purchased from Suncoast Porsche Parts.  The kit includes all parts listed in the Tequipment installation brief. https://www.suncoastparts.com/product/SKUL981SSDS.html
Installation manual for door sill retro - Tequipment Illuminated Door Sill Installation.pdf
Supporting technical briefs also attached
- 578919 Removing and Installing Control Unit for Rear-End Electronics
- 680519 Removing and Installing Inner Door Sill Trim
- 680719 Removing and Installing Cover Strip
- 702219 Removing and Installing Cover (Cold Air Bulkhead)
- 702419 Removing and Installing Front Side-Section Trim Panel
- 720119 Removing and Installing Front Seat
578919 Removing and Installing Control Unit for Rear-End Electronics.pdf 680519 Removing and Installing Inner Door Sill Trim.pdf 680719 Removing and Installing Cover Strip.pdf 702219 Removing and Installing Cover (Cold Air Bulkhead).pdf 702419 Removing and Installing Front Side-Section Trim Panel.pdf 720119 Removing and Installing Front Seat.pdf Tequipment Illuminated Door Sill Installation.pdf
Edited by AR_Groundzero
Forgot Instructions
