ok i am in the process of repairing/upgrading my valve body. im down to 1 last valve and the upgrade part goes in all the way but then gets tight at the very end and when i push it in to set retainer it wont spring back. very carefully i removed the valve and made sure it wasnt bad in some way. checked the cylinder for burrs or anything. looks great. still wont go in and not be tight.
do i go buy a cylinder hone to increase the cylinder id enough to get the new valve set?
in the process of doing so i  had an issue with a few bees that wanted the transmission fluid and when i moved away i moved the tray where the rest of the caps and springs and everything else that went back into the upper valve body moved and everything is all mixed up including the 3 balls for the check valves. i have a diagram for the locations of the parts but trying to determine which goes where by the measurements labeled on diagram dont match up or i am clearly reading them wrong. i dont want to put the wrong parts in wrong port.
how do i determine which one goes where.
