I have a 2004 cayenne turbo with air suspension and need to replace some worn front suspensions parts. I am likely going with replacing the lower control arm and tie rod with the upgraded turbo S version. I was curious on people opinions of the Powerflex polyurethane bushings and if anyone has experience on using them on a cayenne. Also I have found that eurowise sells adjustable spherical end links for the sway bar as upgrades to the oem ones and hoping to hear from anyone with experience with these. Should I just ignore this aftermarket products and stick to OEM.
