Hi all.
I got some really good information here while installing a Traffic Pro on my '01 Boxster. I have Done the C6-A5 crossover so that my amp is switched to on while the head unit is active. My rear deck speakers work well and the CDC-3 changer works.
MY PROBLEM -- Even though the amp is on and the front 4 speakers (2 dash, 2 door) work, the left side seems to be getting all bass while the right side sounds fine. All settings on the Traffic Pro appear to balanced. My orig. CCR-220 unit push out equal tones to these speakers.
Could this be a setting on the TP, a problem with the amp, or a wiring mix up. I used all the same harnesses between the two with the exception of the crossover wire mentioned above.
Thanks for any information!!!!!
