The rear nozzle sprayer on my ‘04 Cayenne S cracked and the water is spraying in the wrong direction. I purchased the replacement part but I can’t find any tutorials online for replacing it. Is this something I can easily do on my own? Anyone know how to do it? Thanks!
I didn't find anything in the service manual.
Here is an exploded diagram that may help.
My guess is that you will need to remove the rear hatch door liner to bolt it in place.
I figured it out! There are three bolts you can see once you open the top glass. You remove the black covers and use a torx bit to unscrew them. Then the whole panel lifts off. I was able to unscrew the rear third light and replace the part.
Edited by abstract88
  • 6 months later...
