I have a '01 Boxster (2.7 manual, not that it should matter?) and neither the driver or the passenger side radiator fan turns on with the AC turned on. After jumping the relays it turns on no problem. This tells me the ballast is working, fans are working, and everything is kosher except for either A) signal wire(to the relay) or B) relays.
After this I went ahead and swapped the high/low fan relays just in-case I was unlucky and miraculously had 2 bad low speed fan relays - to no avail.
Keep in mind there was never any over-heating issues, so in theory the high-speed fan relays should have worked.
this leads me to a signal wire driving the radiator fans from the A/C
My question is what is triggering that? I can't seem to find a diagram on this, so hopefully someone on the forum can help me? Maybe I'm missing something too? feel free! I want to fix it, thanks in advance!
