I just scanned my car after a check engine light. I had a miss fire on cylinder 4. However, also had these fault codes yet everything works: C141, C136 and C144. Any ideas?
Welcome to RennTech:welcomeani:
All three codes are communication error codes for different systems.  Suggest correcting the misfire issue, and then clear the codes and see what, if anything comes back.
Misfires can occur due to faulty / old coil packs or plugs. Take a look at the coil packs, especially cylinder #4, and make sure none are cracked or showing any sign of exterior damage that may indicate internal issues.
Even if you don't see anything, make sure they are the latest design and if they haven't been replaced recently, consider replacing all 6 along with the plugs. Many vendors sell a full kit for around $300 (as of Dec 2022).
