Hi all
my 2005 Boxster 3.2 S has developed a rattle from, I think the transmission at idle.
is 5 speed Tiptronic transmission.
No noise at all when cold only becomes obvious after a run of at least 20 Ks
is strictly at idle as soon as I rev up a couple of 100 revs the noise is gone.
car drives normally either hot or cold.
any ideas?
thanks
Edited by Jim V
Have you checked the transmission and or engine mounts?
Are you sure the noise is transmission related (i.e. coming from inside the transmission) because this would not be common with an otherwise normal driving car.
