I have an 05 Boxster S which after replacing the clutch and flywheel will not start. The lights, windows, radio, fan and top are not working either. The key turns the ignition but the warning lights don't light up either.
There is a lot of things here to consider. Have you got it started yet?
Did you reinstall the crank position sensor?
Make sure all of the things you removed are back on / plugged in.
