2003 Carrera coupe, level sensor hasn't worked since I've had the car.  Time to repair.  Does anyone have any insight on procedure?
Remove the air cleaner, throttle body, and center intake runner. You should be able to see the wiring to the oil level sensor.  Because of its length, some models require lowering the engine slightly to get it out.
