Hi Everyone,
I'm a week into my 'new to me' 2003 C4S.  Absolutely love it.
I fixed a few quick things, but the biggest problem I have right now is driver side footwell has wet carpet, and I know it's my driver side A pillar drain tube thats blocked as my driver A pillar is ruined by water egress.  I can only get about 25% down using weed whacker cable coming in via the sunroof hole and working down until I hit I'm guessing a block.
I need to come up from the bottom, but for the life of me I can't find the drain outlet hole in the drivers front wheel well, behind the driver wheel - before the door hinge.
 It's driving me nuts!
Talking to Loren, since I've a wide body It looks like it's in my bulkhead, ahead of the door, and behind the wheel.
Here are the pics with the liner removed.
AL9nZEXyVhFKgkYd018W0PAU1O55LalVewv3DTCXAL9nZEW-Kh3n1V8bAInyhB2kB-NPBVwDZSWSpohzAL9nZEXDHeHAUEawppFl_KofPJIFI2XPYytYR9evAL9nZEW3fK4wFdtTJVbRlv-3hoYwoKFyNE0lJhd1
Anyone know how to take off the large yellow highlighted plastic to get to the bulkhead?
I removed the bolt at the top but it still held in tight.  The pipe running through it is just a rubber hose that I can remove / replace.
Can someone please let me know how to remove that piece, where the other fastener(s) / bolts are, or link me to a breakdown image.
I feel I'm so close..
