Just yesterday, although the gear select lever goes into 'R' there is no drive, the vehicle doesn't move! Also the 'R' light on the dash is flashing. After trying a number times it eventually goes in drive with a judder. The fault is now intermittent, sometimes it goes into reverse and drives sometimes it doesn't! Any suggestions as to what is at fault? Thanks.
Get the car scanned with a Porsche specific diagnostic tool which can see Tiptronic faults. It may be something small like a single solenoid had failed, but with out diagnostics you are guessing in the dark.
