I'm in the middle of trying to move the HVAC controls from the top slot to the very bottom and had a few questions, I have been through the article on installing PCM which covers this but I had a couple more queries if that's ok.
1. Getting the wires down... is this easier after the vents have been removed? I have been trying with them in place and struggling, or is it just difficult?
2. Will the HVAC fit in the bottom slot without any filing or does it need to be "adjusted"? Mine seems very tight.
3. Will the cubby that was in the second to bottom slot fit in the top slot (beneath the vents).
I plan to have from bottom to top the HVAC, CDR230, another DIN unit and a cubby hopefully.
Thanks in advance for any help, car is an 03S 986 if relevant.
Chris.
