I'm trying to hunt down a 'buzz' in my 997 - the first I've ever had. Problem is its intermittent, but when it happens, it is over coarse or bumpy roads, and sounds like its coming from the instrument cluster/steering column area. I can't seem to locate it though. I've read posts on rennteam and rennlist with some claiming their buzzing sound was from the key fob, others a rust-colored clip related to the clutch pedal, and the last one - that seems very similar to mine - near the base of the instrument cluster - near the tach and speedo. It does seem that tilting and/or telescoping the wheel stops, even momentarily, my buzz, but it still comes back.
Any ideas?
Patriot
I have a "buzz" in similar circumstances - actually was hard to pinpoint because the sound echoed off the dash. Turns out it was the lens on the overhead light, which would vibrate under the right circumstances.
Any ideas?
Patriot
Well I found the problem! If I squeezed upward from the bottom of the leatherette dash trim just to the left of the odometer reset knob, I could stop the buzz. So, until I can make it to my closest dealer (200 miles away) to install some felt tape, I soaked a Q-tip with some W-D40 and brushed the crevice between the small arrowhead-shaped metal-look trim just to the right of the driver air vent and the softer leatherette with the Q-tip. Drove over a coarse road that had never failed to produce the buzzing noise and I'm happy to say the noise is gone!
Patriot
'05 Carrera (Arctic Silver/Black)
