997.1 Carrera S
Front trunk will not open with foot sill switch or with key fob.
I hear the solenoid clicking under hood area... so I assume fuse is fine.
Battery is fine as well... I also tried the fuse panel jump just in case.
ALSO... I just pulled the Drivers wheel well plastic to access the emergency pull cable and it was NOT there???   the grommet was but no cable??
I also pulled the Left side turn signal lens out and don't see any cable?    NOW WHAT????    Can I access the cable from anywhere else?  yikes!!
Edited by GCB
