I just restored my 2002 boxster runs outstanding , tight solid car , all of the sudden my flashers for no reason come on . I remove the key re start they go out drive a bit they come bac on. Also prior to coming on the interior lights on door come on at my wits end
Two likely sources are the headlight switch and the ignition switch.
Try wiggling the headlight switch - if you get strange light responses then replace it.
