I suppose you guys will be able to tell from my request that I am a new porsche driver and loving the whole experience. I just needed some help with oil measurement and refilling. I am finding it really hard to get correct measurement and also not to sure when I should be filling with Oil, is there a general rule for this.
Thanks for you help!
Assuming this is a 986, 996, 987,997 non-turbo (not a TT or GT2) nor a GT3 then measure when it when the car is not running and cold, sitting at least for an hour.
If it is a TT, GT2 or GT3 then measure it when it is hot and running.
Check the level once a month at least. You can do that using the electronic oil level indicator before you start the car cold in the morning or the dipstick. Add about 1/8 of a quart if needed and measure again. Repeat until you are above the middle of the gauge/dipstick marking. Do not overfill the oil as that can cause foaming and poor lubrication, resulting in engine wear.
The vehicle is row C4 coupe 04 manual, thanks for the feedback will action asap
