A friend of mine is considering purchasing a used 2016 CS.  Porsche service records show that driver side Intake Manifold gasket was replaced due to leak and Transfer Case was replaced due to known jerking issue.  Both were done in 2018.  The car has less than 50k miles on it.
Should he consider purchasing it considering the gasket replacement?  TC is a known issue based on my search.
Do any of these have long term side effects that should be considered?  What other things should be checked?
