when i shut the doors there is a creek. i've isolated it to the side view mirrors. when i touch the mirror part with my finger it makes a very athoritative creeking sound. what's the best way to un-creekify em?
ross
There is no mention of any grease or lubricant in the service manual. If you move the mirror using the electronic controls -- does it squeak? Is so, it is in the motor assembly and likely a warranty item.
If not, then it is likely the metal clips that hold the mirror glass in place. You might try (carefully) removing the mirror glass and cleaning the clips (if it's not the motor).
