I need to refill my expansion tank after replacing it. I only siphoned out the coolant in the tank and did a tank replacement. Lost dribbles of coolant from the hose that has the quick connector, other hoses were pretty dry when detached. My question... can I just fill the expansion tank with the bleed valve open or do I have to pull vacuum and fill it that way with my venturi set up.? Seems like a bit much considering I'm only replacing the coolant that was in the tank. Thanks v
I would top it off and leave your vent clip in vertical position.  Keep some extra coolant in your boot.  If your light comes on, on the dash, top off with extra fluid and keep vent open to allow air to vent until light disappears. FBE55397-55F8-412E-B9FD-0F613C1F4B39.thumb.jpeg.0b3acc02af6bdbeb9bad4cd595c10d87.jpeg
Edited by kbrandsma
