14 hours ago, matvrix said:
Would one recommend this as a replacement on a '02 C4?
TIA,
Welcome to RennTech :welcomeani:
Just about any AGM battery is an improvement over the flooded cell units that the cars came with due to longer life and no corrosion; but the model you are referring to is lower in CCA and reserve capacity than the model Bosch actually specs for the car, which is the Bosch S6587B S6 Flat Plate AGM Battery.
